I have a 413 engine block, I want to install a set of Max Wedge heads on the block. Looking for a machine shop (preferably in the Southeast) that can cut the valve relief clearance in the block. I would appreciate your recommendation.
diy half moons with a grinder will work better than the straight plunge cut oem used
yu are doing clearance but the airflow does not like a sharp ledge like stock
figure out where your top ring will come
and figure out your valve position
oem 413 had a smaller bore opening than today's 440 gaskets
I wonder if an "Isky tool" could be used
you might search for 413 HD truck gaskets or stainless marine ones
