Don R McCully
MOPAR Mechanical brakes, pulleys, ignition Parts
Local pickup in La Habra CA ONLY. $250 Lot price
P1000211 Rear suspension components, sway bar parts
P1000212 MOPAR Small block chrome valve covers
P1000213 904 Transmission cooler lines, fuel pump line
P1000214 A-body manual steering shaft
P1000217 Holley carburetor for parts, and additional rebuilding parts
P1000218 Misc. ignition parts, switch, coils, ballast resistors, turn signal ring
P1000219 318 heat stove
P1000220 Misc. nuts bolts, Main bolts, windage tray bolts,
340 exhaust bolts, oil filter plates
P1000221 Disc brake calipers and brackets
P1000222 Power brake booster and brackets
P1000224 Misc. pulleys, automatic floor shift linkage, wiper motor, horn, flex plate, carb linkage
P1000225 Gas tank straps and bolts
P1000227 Stock trans pan and filter bolts, 7 blade fan,
trans kickdown lever, spring, and speedometer gears
