Michael Harmon
Please help!
I'm simply trying to convert to EI using the Mopar orange box and distributor Kit for my '66 Charger with 318 poly. Everyone knows how important it is to make sure that the box is grounded! Right? Ok so, here's my problem. When I mount the box to the firewall (ground), I get NO signal out of it. But when I detach the box (not grounded), I get signal! WTF? This is backwards! But I can't figure out why. I've been working on old Mopars for almost 30 years. Never seen or heard of this problem. The wiring is connected correctly (not rocket science). I've tried 3 different boxes. Same results. I've tried new coil, new voltage regulator, ignition switch and starter relay. No luck. Ive talked to many guys and nobody has been able to figure out this problem. Its completely holding up my restoration because I can't start my engine! I'm completely baffled and need help. If I've left out any other important information, please let me know. Thanks!
