bschubarg
Not everyone has the flexible ground strap connection between the block (where the dist housing is grounded) and the fire wall (ECU Ground.)
There is no ground wire into the ECU so it has to ground through the firewall. The starter (and alternator) ground through the engine block.
If the vehicle is wired where the batteries large cable is connected to the block, and the body is just connected with the negative battery cable pigtail at the battery/fender, any resistance in the large battery cable, and/or engine connection, will create a ground voltage differential when under the load of the starter current (Voltage = Current x Resistance). That is where the flexible ground strap helps equalize the ground levels of the block and firewall
I don't recall the exact ECU box input conditioning circuit, but I think it went through some shottkey diodes before triggering the dwell timing circuit that turns the transistor off.
Nope... E = I/R...... Not E= I x R... Ohm's Law.... Come on man.....
