Sweet5ltr
What is the most complete kit for EFI including the necessary set up for fuel pump. Anyone have any experience with installing them on a basically stock system? It is now a stock 383 but i am looking to upgrade the engine later (years away) so i want to make sure i won't do this again so i would like an EFI that is capable for 450hp to 600hp at the max. So my basic question is i see so many different brands but i can't choose and wanted to know everyone's experience with the current ones on the market.
How reliable are they and easy.
My car is having problem starting in cold weather. also other times i just have problems just getting the car started in any weather. I am tired of getting stuck and spraying starting fluid
in the Carb. Killing the battery...etc...
My set up so far:
1970 Plymouth Satellite
Stock gas tank
stock 383 6.3l
relocated battery to the trunk so i have room for a fuel system in the front if necessary.
I re-did the wiring so i have a one wire alternator.
Rewired with American autowire updated wiring for modern accessories.
Let me know also how easy it is to install. I have already done a lot to this car so far.
Just my honest advice, purchase a quality new carburetor with an electric choke - if you care about actual tuning, order a Wideband 02 sensor like the AEM UEGO or learn to be great at reading plugs [shut off immediately once up to operating temperature at idle / cruise / WOT if you want to tune that area]. If you're having trouble with a simple carburetor, you're not the individual that should adopt EFI. The only parameter aftermarket EFI will 'self learn' is the base map [think of jets & air bleeds], it does nothing to improve your starting ability or AE tables [think of accelerator pump]. With a four-speed car, it will require a dramatic amount of involvement [6-12 months of tuning] on your part to get the system working for you and not against you. An automatic is a little more forgiving, but you will still have at minimum [3-6 months of tuning] to get the base fuel map where you want it. That will require a dedicated laptop, data logging & a steep learning curve on your part.
If it's terrible having to work at starting a carbureted car [no choke] with a battery that's somewhat low on voltage due to the cold weather, EFI would leave you stranded in that identical scenario without a jump.
You or I cannot compare our abilities to someone like AndyF here on the board, that has installed twenty of these systems and literally built an MPFI setup from the ground up. I'm sure Andy would comment that there has been some issues, on not all, but some that even he cannot solve. When you have issues with EFI, they hit hard and it's not always a simple answer over the phone with tech support or a five minute resolution online. Some issues will make the car completely unreliable, and you must be able to diagnose these potential issues on the spot or wait for an individual who can for you.
This is not a factory installed OEM EFI [MPFI / DI etc]. Please do not compare what's currently in your daily driver that has worked for 200,000 miles to what you'll be receiving from Holley, FiTech, or Edelbrock.
I would not recommend EFI over a quality carburetor at this point for you.
