- 10:54 AM
- Apr 13, 2012
- Granite Bay CA
No offense….My front calipers and rotors are
from a 1980's Ford Granada. Not
new. (got them for free). They hooked
up to the Mustang II R&P easily.
The spindles are 70's Pinto.
(super strong).
The 2lb check valves do not cause
the pads to excessively drag on the
rotors, but in some cases will give
the brake pedal a firmer feel. After
initially installing my brake system
(it's more or less custom and pieced
together), I did not have the check
valves installed. Tight footwell in
the cab required modification of the
pedal arm to move it closer to the
gas pedal, and lower it. This changed
the pedal ratio. After the mods the
pedal had a spongy feel, so I
installed the check valves. Pedal
is now firm, and the brakes work well.
Has that been out on the road yet?
Newer cars use expanders to hold the pads off the rotors slightly for less drag. You went the other way. To me, that is only going to cause problems.
One time I was trying different things. I adjusted my brake booster to eliminate all pedal slop. It felt great at home and driving in the back yard. On the road, the pads heated up and then the car almost stopped dead when I coasted. That free play that I eliminated allowed a small space so the pads didn’t press the rotors all the time.
