My 1970 Super Bee 383 A31 car
New Edelbrock AVS2 650CFM is a noticeable and immediate improvement over the old Holley Double Pumper. However it is idling higher than I would like and adjusting the idle screw did nothing so I may have to toy with the timing a bit.
You are going to retard the ignition timing to drop the idle speed?
The entire log kept by the previous owner is him messing with the timing. Pages and pages of logs on timing changes with the occasional oil change, filter change, or other small job. But mostly timing. No idea where it even is right now. First thing we did after setting the original carb, which did not improve the idle, was retard the timing by ear. Just the tiniest twist fixed everything. Don't see why it won't this time. As above, adjusting the primary idle screw on a brand new factory set carb did absolutely nothing so that's the next logical step to me. Otherwise the car ran pretty good.
A friend of mine (R.I.P.) was a multi-millionaire. He drove a used 20 year old Pontiac Fiero until he wore out the second engine and the frame was rotted out. He bought another one and drove it a decade!
I knew a guy like that ...he died last year worth over $22 million. Wouldn't buy anything new if he didn't have to.
Always after a deal...no matter how cheap the job.
Decided to track down the fuel smell. Now the car is in the garage it’s very noticeable. Discovered leaking junction back at the tank. A couple lines right next to each other on the driver side with hose connecting the metal lines to the tank. Manuals is not very clear exactly which ones they are but whatever 3 inches of hose is 3 inches if hose. Fix it tomorrow.
Well that sucked. Was determined to get it done despite the hoses dripping a lot of fuel onto my arm and quite a bit on my face. Arm feels like a burn victim now. Eye not doing great. But finally got the small old hoses loose and replaced. By the time I got it on everything was slick and the clamps kept spinning. A real nightmare since there is zero room for maneuvering your arms under there (I do not have a lift and did not want to jack it up since it is a full tank and would just spill more). Not thrilled with the results but I'll get some jacks and do a cleaner job this winter. At least it's not dripping anymore.
These are what was leaking. The one on the right the most. I'm confused. Why would this leak so badly? Unless I am reading this wrong? The arrow on the bottom left is pointing to the fuel pump, not the gas cap, right?
Useful.
Mine don't route into the trunk. I'm not even positive where they actually end at. Very hard to get around in there with the car on the floor. I think they just cut it off when they did the trunk pan and left it. But they leak.
Fuel pump is on the engine, not in the tank!
Every other car I've worked on had a fuel pump in the tank. Stood to reason the disc cap with two lines running out of it was an in tank fuel pump because that's what they all look like.
The weeping vent lines at the tank is becoming the biggest problem yet. Return line is run to the short vent instead of the sender unit for unknown reason by previous owner, which functionally makes no difference as dumping fuel direct is dumping fuel direct, but seems to have caused some pressurization by denying the tank the appropriate venting and reducing it to one vent. Don't have the space to pull all that and install a new sending unit now that winter is here so I'm opting for a vented cap to restore venting and going to try driving the gas level down lower than the vents. The real problem is the smell. The garage is a gas chamber and now the house is smelling like gas even after I soaked the clothing I wore during the job in the shower for two days, washed it, and rewashed it in the heavy soil 2 hour option. Still reeks. Now the washing machine reeks. And I washed my dog's bed with it so my dog's bed reeks. TWICE. I do not know what I have to do to get the stench of this non ethanol gas out of my life, it spreads to everything that comes in contact with it, and the lady is growing increasingly impatient about it but there's NOTHING I CAN DO. I hosed out the garage floor, I, did the wash multiple times, I replaced the hoses and clamps, washed it all down, but it stills smells.
Another bummer of a day. Discovered all of the nice Edelbrock stuff (8131 pictured and 8123 stainless line) I bought to connect my new AVS2 to the vapor separator won't work because the M1 dual plane intake manifold blocks the fuel filter. No working around that. So I'm back to square one and $100 poorer for trying and still have to figure out how to run these lines and what to buy. I have all the stock metal lines but they won't help unless there's a slick way to connect that small gap between the line and the carb (pictured). I suppose a small length of rubber might suffice but feels cheap. Kind of wish I had just repaired that Holley but it was giving me so many headaches with leakage and then the dumb base ears cracked off so I was over it.
Today I used the cold to benefit installing the new vapor separator. Tore out that ugly old three prong fuel filter and cleaned everything up. Because the metal feed line is 3/8 and the fuel pump inlet is 5/16 I exploited the cold metal and warm hose combo to force 5/16 hose over the 3/8 metal line. Went easy. All fresh hoses, new vapor separator from 521 Restorations, new clamps. Even mounted the VS properly to the fuel pump which was difficult given the pump isn't designed for that but managed to make it work clean. So now I have a half and half 440/HEMI fuel line setup with a 1/4 return line on a 383 car. Started and idled great. Won't have to worry about vapor lock.
I have decided to attempt bending the Edelbrock stuff above and hope it doesn't mar the finish. My friend has the correct tool to bend metal line and also a flaring tool. If it fails I will attempt to separate that line from that eyelet and create a custom hard line using that, or just find a 5/9-20 inlet from a Carter AVS and flare that on. For now the rubber will suffice.
Hood was not seated correctly and the paint has rubbed off down to primer where the drivers side of the nose meets the grille black plastic. I always thought it was off because the hood pins were never centered. Worked with it for a while and it still is not right. Then noticed the driver side grill has aftermarket hardware and I am under the impression something is not lined up correctly but cannot figure out how to remedy this. These bolts are backed off so far that hardware is merely pinching the plastic in place now, not seated in the middle of the original holes. Something deeper has to be bent. I was able to adjust the hood enough to make it better, but not perfect. It's one of those things I can stare at for half an hour and still fail to figure out. Should I take a razor and shave the plastic? Probably going to ignore it for a while.
Also acquired the correct A31 OEM 2863216 metal fan with the stamped number (not the inked one) and a "concourse" level reproduction 2806070 clutch (but it's older so I think it came from Tony before the brand sold) from guys on this forum and I'm not sure if I want to install them now or wait until I rebuild my original motor, which I may never even install. I would prefer to pull my current motor and repaint it and then continue abusing it rather than run the fresh numbers matching motor. But that's a lot of work just to get a pretty look under the hood for a guy with no shop.
Turned out the rubbing had nothing to do with the hood position at all, but the lack of a set of hook shaped "brackets" for lack of a better word that some Coronets came with and some did not, which press the bumper guards deeper into the chrome grilles. These parts do not exist in any manual or parts book that I can find. My suspicion is this issue was discovered later in the production run and these crude clips were created to solve the problem and never cataloged. My car was an early build, Oct 1969 production, and does not have them. After lots of chatting online my theory seems credible. I managed to get one from Pete Skalba, who is a great guy and just mailed it to me. This has improved the position issue but I still need to source or fabricate the other 5.
We had a fast melt and warmup and since they do not salt roads here I gave the car a 45 min hard drive to test out the new fuel system. No leaks. I did have to mess with the timing a bit but now it is running strong and smooth. Tach is still working so that appears solved. Just running rubber from the vapor separator to the carb now but will be solving the hard line issue shortly. And then the dreaded master seal.
