I get that.... and good luck in acquiring the parts neccessary to complete it as you see fit.
My only intent was:
1.) to offer some 'substitutions' if the original parts plan becomes unattainable
the XE268H may be a smaller Cam than the whiplash you were contemplating ? both in terms of Duration @ .050 and Lift ?
However, probably somewhat more street friendly for /break-in, and later idling time etc ?
given the XE268H does NOT call for 150# Seat/300+# over the nose V/Spring pressures like the whiplash ?
The Comp can run just fine at 110# seat/275-280# OTN which is also easier on your used stock stamped steel rockers if those are planned ?
2.) ensure that you were aware of the notoriously low Compression Pistons you are using, as many people are NOT at this stage of their builds and they regret it later no matter Cam used.
IMO, I also suspect your Fuel Economy would be substantially improved at 9.5:1 Vrs the at best 8.2:1 currently planned.
