My 440 needs a new mini high torque starter. Recommendations?
For 1970 440
Appreciate all Starters recommended. I intend to get a starter dodge ram. My only question is would it fit with headers?
Thank You for you patience. I'm new to mopar
Here is a list, go to the parts store the part number is 17466
There is even a smaller starter that works... Ask for one from a 2005-2008 Dodge Ram with a 5.7 and a MANUAL transmission, the automatic starter for this application is totally different and will not fit.
It is a coaxial (planetary) gear reduction design, not offset like the Chrysler and Nippondenso gear reduction starter designs. That's why the motor housing is directly in line with the starter drive axis, thus making the whole starter more "laterally compact".
Be sure and get a genuine starter with a Chrysler, Denso, or Nippondenso nameplate on it. The Chinese copycats flooding the market (advertised at parts stores as "100% new!") are junk. A used genuine starter from a wrecking yard is preferable to a new fake/Chinese or "remanufactured" starter."
Thanks. I might try the 2005-2008 Dodge Ram 5.7 MANUAL transmission starter. I just put on a reman old whiney 3258 and it's iffy (sometimes click no turn). I like the old stuff, but I can't be sitting there clicking either. Haven't decided what to do yet.
I used this one. It fit without grinding anything or changing the terminals (1968 383 RR 4-spd). On the barcode is 17466N.
I didn't realize there is a dust cover that goes behind the mini starter, so now there is a little hole into the bell housing that the old starter covered. I'm going to leave it for now.
I wanted to use the traditional starter, but have had two fail in short order recently. It's just too much work to keep switching out the heavy old starters when they are trapped by the headers.
