EWood66
New Member
Hi, I have a 66 Sat with a 383. The old starter started to fail and by the sounds of things it seemed the relay way kicking in and out causing the starter flutter. At first I thought the battery was bad so I put in a new one. I was able to get the car home but the starter still didnt sound right. I bought a new mini starter since the old one wouldnt spin. Still having the stutter (solenoid kicking in/out) I can jump the hot to the relay and it cranks fine. I can jump the hot to the solenoid direct starts fine.
I have 11.4 volts on the yellow wire that feeds the relay and 11.4 on the brown wire that is ignition 2 going to the ballast resistor.
Has anyone experienced a similar problem and found a solution. I could wire in a starter button but dont want to start bypassing things. I am trying to stay as original as possible.
Thanks, Ed
Thanks, Ed
