scotts74birds
Friday, I'm really happy for you! I've had a project that has been dragging on, but it inspires me to see someone with a running ride. And a NICE one at that! One tip. What I did on some of my older cars [I don't know if you are going for stock or not], I re-wired the headlight switch and Hi-beam to actuate relays with large wires near the headlights. I'm an electrician, and I know that #14 wire, or less, going from the switch all the way to the lights is a recipe for problems. Heat in the switch, especially on High, can cause lots of problems. This way you can run the latest hi-current draw lights you can find, but the interior electrics are only used as a remote switch. With all the hi-current stuff staying under the hood, and close to the lights for no voltage drop.
