- 8:12 PM
- Dec 4, 2009
- Pasadena, Texas
Dab some marking grease on the pinion gear only and rotate it through and see what it leaves on the ring gear. That usually leaves a very pronounced pattern on the ring. As for setting the pinion in deeper or not so deep, yes, you have to remove the back bearing and either take out shims or add them. The front shim only adjusts the pinion bearing preload.
