Dibbons
- 2:28 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
About 1,500 miles into my present road trip (1972 Satellite Sebring Plus with power steering) I found the outside edge of the left front tire had worn down to the steel belts and the passenger side outside edge was worn too, but not so bad. Had to purchase two new front tires and alignment:
from Les Schwab:
Left:
Camber before +1.7 degrees Camber after +0.5 degrees (should be -.25 to -.50)** see chart below
Caster before 0.0 degrees Caster after -0.5 degrees (should be +1.5 to +2.5)** see chart below
Toe before -0.66 degrees Toe after +0.13 degrees (should be OK)
Right:
Camber before -0.3 degress Camber after +0.2 degrees (should be -.25 to -.50)** see chart below
Caster before -1.2 degress Caster -1.8 degrees (should be +1.5 to +2.5)** see chart below
Toe before -0.77 degrees Toe after +0.12 degrees (should be OK)
total toe before -1.42 degrees total toe after +0.25 degrees
THERE IS A NOTE ON THE BOTTOM OF THE LES SCHWAB PRINTOUT THAT STATES THE FINAL CASTER IS OUT OF SPEC (NEGATIVE INSTEAD OF POSITIVE) AND THAT TIRE WEAR, HANDLING, AND SAFETY PROBLEMS MAY RESULT. This was not explained to me when I picked up the vehicle.
This chart is what I found on internet that shows settings recommended for new radial tires based on driving style:
Granny -.25 Camber, +1.5 Caster, 1/16 to 1/8 Toe-in**
Perf street -.50 Camber, +2.5 Caster, 1/16 to 1/8 Toe-in**
Max street -.75 to -1.0 Camber, +2.5 to +3.5 Caster, 1/16 to 1/8 Toe-in
auto-X -2.0 to -3.0 Camber, +3.0 to + 4.0 Caster, 0 to 1/16 Toe-in
Drags 0 Camber, +1.5 to + 2.0 Caster, 0 to 1/16 Toe-in
These are from the 1972 Plymouth Factory Service Manual which Les Schwab tried to duplicate, but that I have read are NOT valid for modern radial tires:
factory specs (DO NOT USE) are listed here below:
Camber left +1/4 to + 3/4 (+1/2 preferred
Camber right 0 to + 1/2 (+1/4 preferred)
Caster for power steering +1/4 to +1 1/4 (+3/4 preferred)
toe in 3/32 to 5/32 (1/8 preferred)
Caster for manual steering 0 to -1.0 (-1/2 preferred)
from Les Schwab:
Left:
Right:
