Curiousyellow71
From what you described....If you don't have much cylinder taper, (need to measure like what has been mentioned) I think you can easily get to your hp goals with the stock cast pistons. If your pistons have a dish....cc them and the 452s and use a compr. Calc..... you will have a better idea what you need for a cam. You can machine a few things and raise the compression some. I would not be afraid of ceaning up the valves and seats your self....you don't need fancy tools...Before we had a valve/seat grinder we did it all the time. You will learn a lot if you do it yourself....and I don't think you will have any trouble with advice around here. If you have a good solid motor to start with and so far it sounds like it....nothing wrong with saving some money and freshening it up. Now if you said 400hp...I would advise differently.
