whayden2003
I have filled those areas in the past with “all metal”. Look it up. Easy to work with. Not to expensive. Is it the right way no. Will there be a chunk of all metal on the ground after the car rusts away. Yes. I do still use it properly in areas where the old lead joints were. Like roof to quarter seams. Be well within your skill level to pull the glass and do as the other guy said and treat the rust with whatever you chose. Eastwood makes stuff for that. And filling it with all metal and priming it.
