Do you have any pictures of the distributor - springs, weights cam slots. The stock springs usually include one, very heavy one with a loop end on it with a lot of slack. That spring doesn’t come into play until the weights overcome the smaller spring first to rotate the cam and sling them out enough to take up the slack in the big spring and then from there, it’s stiffness slows the advance curve way down. I don’t know the rpm that big spring may top out at - it could be as high as 4500 to 5000 rpm’s. If that’s the case, you are only seeing a part of your total centrifugal advance by reving the motor up to 2500 rpm in the driveway. That could be another part of the mystery.
Got any pictures of the inside?
If dwell/gap gets way off, the motor will run poorer, but as Geoff said there is a broad range in the middle that you can’t really tell much difference from seat of pants. But if you don’t get the gap closed down and the dwell up, you are losing the advantage of a dual point and it’s increased voltage stability at higher rpm’s.
