Need info on cam bolts
Ray70Chrg
8:26 PM
Scottsdale,Az.
I'm in the process of changing cam, lifters, springs, and all the rest. The cam going in is lunati voodoo 703. In all the stuff I ordered from them, you don't get the 3 cam bolts. Old cam is single bolt. To make things worst they haven't responded to my question about what part # of theirs would fit their cam shaft. I have looked thru Summit & jegs for lunati cam bolts and can find no info for lunati cam bolts for mopars. Chevy and Ford of course, but no reference to mopar installs. It seems that 5/16 bolts are common for C and F but no reference to length or thread count. Can someone give me part# for any vendor that you have used for a voodoo cam that needed the 3 bolts. You would think Lunati would charge you $3 or $4 more for cam shaft and throw in the bolts. Thank You
Mopar 3-bolt cams use 3/8-16 bolts. 7/8" is a good length. Make sure to check the clearance between the bolt heads and timing cover, sometimes depending on the timing set they're awfully close and need the heads shaved down a bit.
