vin_vl29u
When you hear an old mopar crank, start then die after letting go of the key, it's usually the ballast resistor. Since it is bypassed when cranking. So check the resistor or the wiring for it.
Yep,,, you knew it was bad.... And it had to be grounded too because you said so..... Boy your smart!Beacause the switch is junk thats why. Seen it many times, my car just last summer.
Good to hear you got your lights working zoombie.
BTW my remark was to have him TEST the thing before being a brilliant parts changer like you apparently...
Zoombie had a spare switch, take longer to test than swap out the spare. But what do I know, I'm just a parts a parts chaser.
