beezee
There is a pilot bushing in the back of the crank that supports the transmission input shaft,if it is worn or missing it will vibrate as well.
yes if its in neutral ,clutch not pressed in it vibrates at 3k
It should be the same diameter all the way through. Make sure your tanny is centered before reinstalling it. If you are out by .004 or more you'll wear out the new pilot bushing/bearing. Plus you always get a high speed vibe through the whole car. Annoying and bad for your engine.
cant seem to find any info on the problem i have.....:angryfire:
so do i have to drill the crank out now?and how do i measure if the transmission is .004 out or something??thanks
could i use the part http://www.moparts.org/Tech/Archive/clutch/1.html??
or is it only for ones which the hole is not there
See post 22 from trimmer. The mopar chassis manual has the answers you you seek. Far too much info to try and post here. There is even an explanation of how to make sure the trans is centered to the crank.
Is there a enough of a market in qatar to keep a mechanic busy? Things are getting crappy stateside. Might need to bug out
