Need some help with what fan and clutch for 69 rr
GearAddict
10:00 PM
Tampa, FL
I have a 69 RR with a 26" 3 row radiator out of a BB C Body. Previous owner installed an undersized electric fan. I'd like to get rid of the electric and go back to a mech fan and clutch assembly.
Can someone guide me on what part numbers or a description of the type of fan and clutch needed?
Thanks Prop, I actually came across this just before I saw your post. I went ahead and ordered it and installed it today....problem is that the fan blades hit the bottom tank of the radiator and prevent the fan from spinning free.
the radiator in the car appears to be a 26" 3 row out of a C body. I don't know if this matters but it does seam like the core of the radiator is pushed out about 1" from the radiator support by the welded brackets mounted to the radiator.
Any thoughts? Time for a new radiator? I assume this fan should have fit.
Just thinking, are there different height fan clutches?
If the fan was a half inch closer to the engine it would be fine.
