new shifter for 1964 pushbutton trabsmission
flyingfarley
5:49 AM
edgewater Fl
I have a 1964 pushbutton transmission and my pushbutton assy is acting up...does anyone still make a floor mounted shifter that will work on my pushbutton transmission or am i out of luck....
thanks
Flyingfarley
You can lube your pushbutton unit and cables. Check the condition of your cables.
Find a factory center console shifter with factory cables. New cables are available.
If your push button assembly is wore out? I have a nice used one for sale!
The push button shifter is a very stout and simple unit. 99% of the issues are the cable. What issue do you have with it? I've had them apart, not much to wear out
Cable operated transmission cables are adjusted by the control adjust wheel where the cables enter the trans. Do you have a FSM?
Push Button Shifter Bracket
P4300002.jpgHello moparsteve636; I have a 1962 Dart project. I need the bracket that attaches the push button shifter assembly to the dash as well as the park lever. Would you happen to have any of this or know someone who does? Thanks, Scott
[email protected]
