Canadian1968
When I got the charger out this year and took it for its first few drives I started to notice a slight miss fire at very light throttle. My first guess was some old gas in the tank. Then I noticed I had a cracked spark plug boot that was allowing spark to arc to the header. i thought for sure that was the problem. But those problems have now been eliminated. The miss is still there.
It is most noticeable when pulling away from a stop, at light throttle. The lighter, the throttle the more noticeable it is. The opposite, if I accell harder, its much less , or not there at all. Once at speed the car seems to cruise fine. Throttle response is still fine. The only problem seems to be the slow pull away from a dead stop.
When I have problems like that I always ask myself, " Ok what changed " in this case, there is nothing that I did. But there is something different with the gas! I am in Ontario Canada, I always get my gas from the same place. A Canadian tire around the corner from me , always had 91 octane with NO ethanol . This year I noticed a sticker on the pump " 10% Ethanol". A quick search shows that basically all pump gas in Ontario now has ethanol in it.
This is the only variable I can think of.
So my focus is on the carb. My wideband show lean blips in relation to the miss. The light throttle is pointing to the transition from idle into the main circuit. The miss is very subtle but still noticeable, so the change that needs to be made is going to be very minor I believe. The carb is an old school 3310 Holley. So it doesn't have near the tuning option (well without drilling ) as some of the new units.
What are some thoughts, suggestions???
