1toolguy
The rear fenders were repaired with bondo, now it is breaking loose, gas tank has a leak, some rot on the under side and interior needs some help.
The quarter panels and underside will be tough, you'll probably need to find a need a donor car. The gas tank is easy as there is a replacement, if I recall correctly it's from Spectre and is actually listed as a 20 gallon tank for a 74 Charger but it's the same tank (BTW- If you're doing a resto and looking for a stock 25gallon tank, PM me and I'll make you a great deal on a great condition used one). The interior is no problem as carpet is readily available from a variety of sources and the rest is just a good upholstery shop away.
As to your "hard to find parts" comment, just make a post here. Chances are someone has either found a source or has discovered which parts interchange from other models.
