Got my press together and pushed the pivot pin in. I need an experts opinion on if this pin is in right. This is my firsttime working on a M
opar front end
According to the shop manual, bushing should first be pressed on shaft then the whole assambly pressed into LCA. That's the way I did it, using a bit of a pipe outside the shaft so the press hit the bushing flange.
Doing one side at a time. I will do other side the way you all said. I should have asked first. My bad Thanks Do you think I should take it apart and press a new bushing onto the pivot pin and then press into control arm. Or do you think it will be ok?
