newbie from virginia.magnum swap flexplate help
speedcreed
New Member
2:19 PM
virginia
hey guys I need help.i have a 1971 charger.it is currently a 318/727.i am converting to a 5.2 magnum out of a 93 Dakota.i have a tci super street fighter tranny 727 a hughes performance 3000 stall converter 10 inch.my problem is the flexplate I want to use stock efi with cps.where will I get a magnum flexplate in a 10 inch bolt pattern for the cps to work on .please help
I have no idea....but wanted to say welcome.
Has the 727 got the location for the crank sensor? You will need it if you are running the stock 93 efi with cps. Also the 93 5.2 magnum will hardly out perform you 318 with 4BL and decent cam added as the cpu is very limited. But it is your car and if this is what you really want to do go with it.
Wanted to say, Welcome, sorry I can't help much but see you hot a place to go. Hope it helps. Good luck
