69greenleaf
I need some help or advice with this problem. I have changed the coil and also checked my distributor and my ignition switch itself. I have gone through the wiring diagrams and check all of the connections into all of the wiring blocks and all of the connectors themselves. still no spark. One thing that is confusing me is that there is an ECM module mounted to my inner fender but i cannot find this module anywhere in any of the diagrams i have looked at. i have checked to make sure everything is grounding the way that it should be and that the pickup in the distributor is spaced correctly, and the rotor and cap on the distributor are brand new. Does anyone have any idea what else could be causing this problem other than a wire being broken in the sheath or a wire grounding itself out somwhere? Any help or advice would be greatly appreciated.
