jogirob
Parking lights work normally. Brake function work normally. If I do emergency flashers it will light up indicators in the gauge cluster but neither front nor back exterior lights will flash. When I signal left or right nothing happens with the gauge cluster indicator or exterior lights.
I read through a couple threads where replacing the flasher solved the problem. What are the odds that both turn signal and 4way flashers are bad?
I almost wasn't going to mention the backup lights but maybe you guys know something I don't.
I'll be taking a closer look at all of the fuses and probably swap out the flashers just for the fun of it since they're pretty cheap. Just curious to hear your guys' take on it. Thanks all!
