View attachment 180618 are e body harnesses interchangeable with B BODY?
well... we can say yes, but with some notes ( being strict )
70s and 71 Es didn't got the NSS ground signal into the cab, same as 71 B... so in a perfect match, all 70/71 E will be a perfect match with 71 B.
then all Mopars in 72s required the neutral ground signal into the cab to controling the seatbelt signals. So a 72/74 E body will be the perfect match with 72 B
these last won't be a perfect match with 73/74 B bodies just because the Ground wire from NSS is way shorter on these due the diff location of Starter relay, BUT would require just to get it shorten to the location of Relay, that's all
ANOTHER NOTE... to use the E body on a 70 B body OR use the first one you shown, you can simply remove the terminals from the existant plug, and insert it into the wiper plug ( or any plug existnatn in between, can't recall if 70s got an extra plug in the middle ), BUT just the black wires which are the reverse signal wires!!! thats all.
the 3rd wire, brown traced if existant into the plug, doesn't need to get it into the cab, just to the starter relay. This setup began on 72s
