MWFan
Please see post #22Well now we know it's not off idle stuff but secondaries kicking in too fast. Now most likely a spring change is needed in your vacuum secondaries.
Andy
(Happy New Year)
Andy
(Happy New Year)
Good point. Ill check.Your last entry talks about stomping the throttle when you get the stumble. If that has beed the case the whole time yes the stumble can very well be rear of carb. and req. a spring change in the sec. canister.
When you are doing your idle adjustments with a vacuum gauge proper is to check vacuum idling IN gear with emergency brake set unless your car is a 4 speed.
Ron
Let me be sure what you are requesting. Adjust idle mixture screws for highest vacuum with car idling in gear, (instead of park) correct?Please answer my last question that I PM'd you with either here or in a PM and we can make this throttle response perfect with just a little more.
Ron
Done. The float levels were a little low, but the idle mix screws made little significant difference.yes sir, in gear, brake on, tires locked, and vacuum advance unplugged but carb. port for it plugged and after you get best/highest vacuum reading on each side or all 4 if you have 4 corner then reinstall vacuum advance and you may have to actually lower the idle screw
Thank you sir!Very cool, if I can ever be of help just ask. There is a lot I don't know but I'll give you the 2 minute tour to what I know anytime!
Ron
