mopar 3 B
- 10:00 PM
- Aug 25, 2014
- Kingsville, MO
Don't worry about the pressure. Just stay away from cheap 80 psi gauges.
Better too much oil pressure than not.....oil pressure is cheaper than bearing replacement. The GTX HIGH VOLUME PUMP AND 10W-30 MOBIL1: Cold=80 psi; hot @1200rpm=60 psi; hot @ 4000rpm=75 psi. Zero wear on distributor bushing or gear.The old S/SS car I bought would wrap the needle past 100 cold. 75 warm idle. 100 down the track. It wore the bushing and shaft about every 150 runs. No problem other than that. Mim
I'm totally aware of the differences between the volume and pressure relationship and I want a HIGH VOLUME PUMP.If there is distributor gear and bushing wear. Just maybe the wrong metal types are being used.
Let's also not confuse volume with pressure.
I look at it this way. That big oil pump and it higher pressure is worthless without the right bearings.
The high pressure relief valve in the oil pump limits the nax pressure developed snd the burst rating of the filter prevents this from occurring plus I use WIX FILTERS # 51515RWhen the oil filter blows off the motor on a cold start, that's probably too much. (Been there, done that).
.... unless you are attempting to boost warm oil pressure, with an adjustable pressure relief valve....The high pressure relief valve in the oil pump limits the nax pressure developed snd the burst rating of the filter prevents this from occurring plus I use WIX FILTERS # 51515R
BOB RENTON
I WOULD NOT use an adjustable high pressure relief valve in the oil pump. It is a standard MELLINGS/Mopar high volume pump with the relief valve spring for that specific application WITHOUT any shims to achieve my results. My operating specs are determined by bearing clearances and oil viscosity. IF you are proponent or understand the concept of the HYDRODYNAMIC WEDGE LUBRICATION THEORY of journal bearing, a higher volume of oil promotes better bearing cooling and allows better film strength at the boundary layer interface..... unless you are attempting to boost warm oil pressure, with an adjustable pressure relief valve....
and miss really bad on the adjustment......
and hadn't yet learned not to use Fram filters.
( I seriously pegged a 100 lb mechanical gauge, my guess? 130 lb)
