Garys1969RR
My suggestion, buy this already built 440 short block for 200.00, if still available. Use the fresh 906 heads you have. Use the 509 cam you have. Then you still have money left over for gaskets, and misc. You will be miles ahead with a 440, compared to a 383. You should still have a couple hundred left to drive to Detroit and get the 440. Take a Toyota P/U and save on gas. The 440 will fit nicely in the back. That motor will run great with the 509 cam, 906 heads, and Keith Black pistons!For sale a 1976 440 block with cast crank, main caps, keith black pistons and connecting rods with arp bolts. the engine was line honed 1500 miles ago. all components are fine just moving in a different direction. $200.00 for everything. 1-734-775-0738. located outside of Detroit. p,s, the block and pistons are .060 over \
I am running the 509 cam in my 451 and it works great at straight up position. And I would advance yours 4 degrees to help build cyl pressure at the low end. Also, you should run at least 10 to 1 C/R with that cam. It likes compression, gears and a hi stall T Converter.
