john.thompson068
Has anyone had any problem with the orange coolant eating away at their motors and gaskets? Recently I have seen a slick oily residue on the valley pan of my 440. I don't really know what to think of this yet as I cannot tell what it is. It may have something to do with the motor having been running around at 220 degrees. So I have installed two 10" pusher fans and am waiting for a 7 blade flex a lite fan to replace my 5 blade fan. Also, the car has a shroud.
After having the motor rebuilt 5 or 6 years ago I used orange anti freeze with an aluminum radiator. About 6 months ago and less than 50 miles ago, I topped off my system using some green anti freeze out of ignorance (coolant is coolant, motor oil is motor oil). It probably only took a 1/4 of a bottle. I recently removed the radiator and drained the dark orange coolant (thanks to the green). I can see some grit in the bottom of my radiator. I have no access to a garden house as I am currently an apartment dweller. I will flush out my system with the heater running using buckets of water until it comes out of the lower radiator hose clear when I drain the radiator back into the bucket. Then switch back to green. The bottle of green coolant actually said to do this. Its directions said to drain the radiator, fill with water, run the motor with the heater running for ten minutes, then drain the radiator and fill with coolant. It sounds like a good idea.
