Radiator Troubles.....US Radiator.
Thanks for all the input guys.
Nothing worse than walking in your garage, looking under the front of the car and seeing a puddle of coolant !!
I'll post up the results when I get the radiator back with prices, quality, PIC's, website details and links.
Tom's Radiator is a family run shop, since 1965.
I'm glad I found it and I hope everyone else here can try the place for re-core needs.
My OE 054 radiator was recored by US radiator before owner Don Armstrong retired and sold the company. It's one of the best parts of the car.
As others have suggested, consider GLEN RAY RADIATORS. I purchased the OEM MAX COOLING RADIATOR # 2998956 (more tubes, bigger tubes and more fins/inch) that Bob offers. All brass and soldered construction, guaranteed for as long as you own the car. I use a 50%/50% DEXCOOL water mix with a16# cap. The radiator cost ~ $ 1400 + shipping (approximately $40 to Decatur illinois). The cooling system is NOT the area to try and reduce costs. The car is an original RS23V0A****** an original 1970 GTX six barrel, car 4 speed car. Just quit fiddling ******* around and do it right the FIRST TIME. Use a Flowkooler pump, shroud, and #2806070 TORQUE DRIVE CLUTCH and 7 blade fan. My temps run ~ 185°F (normal operation) to 200°F (with a 100°F ambient day) with a 180°F hi flow thermostat. IF YOU CANNOT afford the $1400 price save your money until you can afford the price for admission....do it right....just my opinion of course.......
BOB RENTON
Everyone here seems to jump to that, but there are still old school radiator shops out there that can recore and OE radiator just a well. Bob's got a shop, he just needs to find an old OE radiator for the next round to have it recored. Cores are still obtainable. I highly doubt GlenRay is making their own cores.
Fewer and fewer each year, unfortunately. I had a guy in N KY that recorded my 62 radiator back in 04ish. Still going strong. He is now out of business.
Yep, like I said my shop just down the road will be done on repairs when the Father stops "wanting something to do". He's now about 77 years old.
And with fewer shops, they get more expensive. I spent $300 to re-core the original in Baby Blue in 2013, it was $800 to do the current GTX last year.
Yes, there are still some old school shops around to do radiator work. Yes Glen-Ray does not make their own cores, but Bob does spec the type of cores he has built for himself. Remember there is a difference between a $400 recore and a $1400 restoration of a radiator. The cheap recore means the guy doing it is working for next to nothing and using the CHEAPEST core he can find because he thinks he is doing you a favor, which lots of times turns out to not be such a favor after all. I understand not everyone has a caviar budget also. Bob does stock some used radiators to restore for customers but most of his work is restoring a customer's existing rads and new reproduction units also. Even if you aren't in the market for a Glen-Ray rad Bob will also answer heating and cooling questions too.
My guys $400 job, 6 years later.
