Well it's only one price and you really need to list what will be done and what parts are used.
			I second that and the one from Dwayne.Well it's only one price and you really need to list what will be done and what parts are used.
Welcome to the mopar world lol
If you dont have the machines (very expensive). Or the knowledge on how to build Then engines are expensive. Same with everything else, trans, body and paint. Peoples time, experience/knowledge, and Facilties/tools sre all worth something. So 2 choices. Pay, or learn to do it yourself. And dont forget the tools, space/building, electric, heat you'll need.These days i feel like everything is ridiciously overpriced.
And itll be a stone. 300hp at best.To add salt to our wounds in the Mopar world, You can buy a NEW 350 Chebby engine complete starting at about $3000. No boring, hot tanking, installing cam bearings, mains and rods bearings, new rings, new cam, new valves, springs and the list goes on. Too bad we are so dedicated to Mopar, because it's in our DNA. I wouldn't have it any other way. Mopar engine or no engine!
Here you go.I'm waiting for the hovercraft conversion.
Exactly. WHEN you get your pants taken down, just leave them there. It will make it easier for the next guy....Welcome to the mopar world lol
I just picked up my 383 block yesterday. Hot tanked, .030 bore/hone, line hone, cut to zero deck, decks squared to crank, new pistons pressed on rods, original rods reconned, (2 replaced), cam bearings, main and rod bearings, new freeze/threaded plugs. Had the crank turned separately for $350. Block work cost me $1700, and I think it was well worth it. I have to assemble it though, which is what I wanted anyway.This equals to 1,140.76$ in todays money.
That said i already had a shop telling me it would be 10 grand if i should ever need my 440 rebuilt. Yeah sounds fair...
I believe mine was about $300 to build a short block. It was also in the machine shop for just over a year. Luckily I was not in a hurry at the time.Around here, good performance machine shops are fairly expensive and have back logs of work.
I am curious what shops charge for assembling the engine, also stock vs Stroker/Aftermarket parts?
100 % Agree on the machining part,but as parts go,I just did a quick search comparing the 440 pitons stock to the 396,427 chevy motor n the price was 200.00 plus for the mopar,it doesnt take long to add upIt doesn't cost any different to machine a Chevy or a Mopar. All the stock rebuilder parts are in the same price as well.
Doug
. They got the 30 hp. 4-banger flathead back from this rebuilder. $12000.00 ! This is basically the same motor that went in wartime Jeeps. They had to have new pistons and valves made, plus poured babbit bearings. This being Canada, our $1.00 is only 75 cents U.S. , but that is still a lot of DOH!
