Mopars & Missiles
- 8:57 PM
- Nov 22, 2010
- Northern Indiana
Latest on my voltage regulation problem,
I finally got back to the garage today and did some more troubleshooting to isolate the unwanted voltage drop in the wiring to the voltage regulator. I had suspected it would turn out to be excess resistance in the Ignition Switch contacts. I was wrong! Turns out the problem is in the Ammeter in the instrument cluster. There is a little over 3 ohms of resistance in the ammeter (3.2 ohms) which is causing the voltage drop. The ignition switch itself only measured 0.3 or 0.4 ohms, so it is insignificant compared to the Ammeter loss. Also, when cycling the ignition switch a couple of times to "wipe" the contacts, the reading will then go to 0.0 ohms. So I need to pull the ammeter now and see what's going on in there.
Ratroaster, not saying this is what is causing your problem too, but wanted to let you know what I found just in case it can help you or someone else that is having a similar problem.
