Panther Pink Fuel Injection System.
58belvedere
4:53 AM
Newark
Killshot EFI - Pink for Breast Cancer Awareness
Killshot EFI - Pink for Breast Cancer Awareness​
Originally an April Fool's joke on our social media, the Pink Killshot EFI System turned into an actual product after so many people responded so positively to it and requested we start selling a Pink version; a true ode to our commitment to doing business "for the people."
But our commitment to people doesn't stop there. As Pink is commonly associated with breast cancer awareness, Aces has committed to donating $50-100 to the Breast Cancer Research Foundation for each Pink Killshot EFI system that is sold in an effort to support the Foundation's cause of continuing to fund research that helps accelerate breakthroughs in medical science that will improve treatments, deepen the understanding of the disease, and, quite simply, save lives.
Visit www.bcrf.org for more info or to see how you can support their work!
Aces' Killshot EFI system is one of the most advanced throttle body injection (TBI) systems on the market. The Killshot utilizes four 100 lb/hr fuel injectors, giving the system the capability of supporting up to 650 horsepower. The system includes the throttle body (with integrated fuel injectors, TPS sensor, MAP sensor, IAT sensor, and stepper motors), wiring harness, WBO2 sensor, ECU, and a 5” touchscreen handheld programmer for easy tuning and monitoring of engine data.
The Killshot system fits most 4150-flange 4-barrel intake manifolds and is designed for easy installation and tuning. For stock to mild applications, the calibration wizard and self-learning features mean advanced tuning knowledge or experience is not required. But for more aggressive or performance oriented applications, Aces offers a full tuning software suite and USB data cable for advanced manual tuning.
Aces designed its throttle body systems with the ECU separate from the throttle body. This alleviates any issues with possible damage to the ECU from unwanted engine heat or vibration. This is a common problem with other “all-in-one” style systems on the market.
Whether you are building a budget beater or a boosted racing car, Aces EFI’s Killshot system has the technology and advanced features you need, in an easy-to-install, easy-to-tune package so you can take your ride to the next level!
For timing control, the Killshot requires a magnetic pickup or hall effects distributor and separate ignition coil. We recommend our Black Jack Pro series distributor and ignition coil for a plug & play experience.
Aces EFI Killshot™ TBI System Features
32-bit software (OEM standard) that manages input/output signals, voltage, and RPM faster and more consistently than competitors
5” full-color touchscreen handheld with built-in GPS speedometer
Integrated coil driver for ignition timing control
Simple calibration wizard for initial setup- no laptop tuning required.
Self-learning fuel table
Dual fan control
Step retard for nitrous control
Boost compatibility (using laptop software)
Remote-mounted ECU to avoid common heat/vibration-induced hardware failures
3-bar TMAP sensor for boost & nitrous compatible (using laptop software)
Free laptop software available for pro applications
Compatible with Aces’ handhelds, dashes, CAN modules, and TCMs.
Bosch 4.9 WBO2 sensor
(4) 100 lb/hr injectors
Want to buy it as a Fuel, Top End, or Master Kit? Let us know in the box below and we will reach out with a custom quote for 5% off the Killshot and it's kit items!
(Scroll down to the table below for an explanation of Kit versions) (pics won't take) Cranky, I see why.
