New in the box!
Chrysler Denso mini starter $155 new $100 + shipping.
Edelbrock high flow water pump part # 8814 $120 shipped
Melling M-63 HV oil pump $65 shipped.
Melling IS-63 heavy duty oil pump drive shaft $40 shipped.
Melling stock pan pick up lost the box. $20
fel pro 383-440 gasket kit Part # KS 2110 $50 shipped.
O.E.M. parts left
L-R fenders in primer ready to be sanded and painted $400 pair.
DS door in primer needs paint $150
glove box door Perfect no cracks $40 + shipping
69 ignition switch and key $25+ shipping.
hood hinges dirty bu very good shape $40+ shipping
satellite fender emblem w/ perfect back and mounting pegs $20+ shipping
Horn pad $25+shipping
Horn ring $20
I can send pics on request.
#1. I need the visors. Will take one if that is all you have. #2. On the firewall to the to the right of heater hoses there is a part that has two stems coming out for a/c if you can get if off I need #3. Front seat belts if you have not sold to MO70Roadrunner #4. Rear inside window trim only need bottom but would take what you have to not break up set #5. Narrow trim <drip rail>that starts over the top of vent window ends at bottom of rear window as it curves down toward rear, could use both sides #6. Lower dash pad, any color # 7. Fan shroud 26” if Grandwazoo does not want to buy # 8. 26’’ radiator # 9. A/C radiator # 10. RR horn bracket only, if you do not want to break up I understand # 11. Door panels , any color..mine have curled up at bottom #12. Battery hold down with J-hooks
