SOLD Parting out 62-74
I should probably be looking for a steering column for a '72 satty, preferably floor-shift, but either would work (my bearing, T/S switch, etc. is getting pretty sloppy), drip-rail chrome, back side-window-glass gaskets (or whatever you call the chrome/rubber piece that goes between the front and rear windows on a 2-door) and a rebuildable set of bucket seats...
Mark:
Would you happen to have the emergency brake mechanism for inside the car for a 69 RR? I have a friend that might need one for his car.
Thanks!
Looking for wheel well trim for the 67 satellite, also, the tail lights if you still have them. Thanks.
I need a good 67 B body front right brake line.
I've parted out alot of 62-74 B-bodies over the last decade.
Have columns, dash frames and parts, hardware, seats, H/L bows, wiring, ect
From Southwestern Desert cars with little or no rust issues but also means that I don't have alot of soft trim and parts.
Ship worldwide. Also free delivery to several shows across the country.
Here are the cars I have in the yard now.
74 Coronet 400BB
73 Satellite
72 Satellite
72 Charger
66 Coronet 2-dr sedan
66 Coronet 4-dr
Just parted
67 Satellite
73 Charger
74 Charger
62 Belvedere
65 Belvedere
64 Polara
Also have A, E and 61-80 truck parts.
I need a good front right brake line for a 67 B body with 10 inch drum brakes. Any help would be greatly appreciated.
Looking for passenger side rocker panel molding for 1972 Coronet
do you have window mechanism parts for the 62 belvedere i need all of it front and rear . how much
I need a 1967 B body right front brake brake line that runs from the wheel well, across the firewall, to the proportioning valve. This is for standard 10" manual brakes.
Hi I'm looking for the left and right chrome front fender moldings for a 73 charger SE. Also a rear ashtray for the same model. Shipping to Louisiana. Thanks
70-74 dodge charger.
74 Coronet 400BB
73 Satellite
72 Satellite
72 Charger
66 Coronet 4-dr
Just parted
67 Satellite
73 Charger
74 Charger
62 Belvedere
65 Belvedere
64 Polara
Hi. This may be a pain but i could use some help. I'm converting a 74 SE model to a rallye/RT style. I've got the hardware to change the rear glass to roll up style. The problem is the, c channel( I think) for the lower roller on the regulators is not on the inner 1/4 panel on an SE model. Could you please look and see if that is a welded on or screwed on(bolted) piece Even a photo would be much appreciated. If we have to manufacture them ourselves at least we'd have an idea of the angle and attach points. Thanks for any and all help.
Scott,
" no phone / email in ads - please use PM "
Please read the rules
Dang guys, I didn't know this old ad was still floating around. I better get cracking.
Looking for a switch assembly, buttons etc for ac/heater controls for 63 Sport Fury--thanks sportfury63
Just got in a 63 Belvedere so I'll see what it has.
Any under dash and engine compartment wiring harnesses in your '66 Coronets. If so what shape are they in and how much? Prefer both from same car but beggers can't be choosers.
Have the dash harness but is not in very good condition. Don't have the bay harness.
I am looking for a drivers door panel for a 73 satellite.. Prefer a white one if U have one..
Upper or lower?
looking for seat brackets for '62-'65 b body. thanks
I have those. 50.00 plus shipping. Can sent pics.
'62 Dart 4 door sills plates.
'62 Dart speaker grille.
May have 63 Belvedere sill plates. Are they the same?
Don't have a good speaker grill.
need radio bezel 65 belvedere ll
I'll check.
I probably have a column shift column. Don't have the drip rail moldings or bucket seats. The quarter glass seals are being reproduced.
thanks
Mark:
Thanks!
Already talked to you.
Sorry I don't have either right now.
The hard line or the flex hose?
thanks
I do have a pair of them. 83.25" long I believe.
For 2-dr Hardtop? May have 63/4 regulators. Don't think they are the same?
Ok there is the answer. I'll check
I'll check
1963 Polara rear valance or anything else for this vehicle
Have a 63 Belvedere but sorry no Dodge valance.
Scott,
When doing this conversion there is a channel that is spot welded to the structure. Here is a pic.
It is welded on the back of this panel. I've outlined in red where it sits and the 3 spot welds
Up Date;
63 Belvedere 4-dr
64 Belvedere 2-dr H/T
74 Coronet 400BB
73 Satellite
72 Satellite
72 Charger
Parted out last year.
66 Coronet 4-dr
67 Satellite
73 Charger
74 Charger
62 Belvedere
65 Belvedere
64 Polara
Gearing up for the MATS and S-Fling. Free delivery with pre-paid.
Thanks for the photo on run channel mount. Any chance you'll be pulling the rear windows for sale and could drill the spot welds and send channels? That would be a lot easier than trying to fabricate. Thanks, Scott
If he does not have a good underdash harness I have one out of 66 Belvedere
Looking for a chrome passenger side door mirror for my 71 Charger.
Sorry I don't have one right now.
I checked and sorry the control is already missing.
Sorry don't have the moldings but have an ashtray.
Do have some. PM sent
Sorry I didn't have one.
