I should have some and could bring to NatsLooking for headliner bows for 62-65 2 door sedan. Not sure if hardtops or 4 door will fit.
Looking for seat belts that would fit a 63 Plymouth savoy 4 door not really worried about color. Would also need all the hardware.
Do you have the heater/defrost/cooling pushbutton control out of a '62 Dart or Polara B-body? (Probably used in later years too.) This has 4 buttons for OFF, Heat, Defrost, and Cool (vents). I only need the control switch but can take the assy with the heater temperature lever & bracket and the buttons, whatever is easiest for you.
The control's PN is 2256681. You may have to take the 2 screws off the bottom and remove the heat temp lever & bracket to see this.
I need one that does not have any evidence of the plastic housing melting from the blower contracts inside the control corroding and getting hot.
Thanks!
If there is A rear passenger quarter panel and A back bumper for A 73 or 74 satellite in good shape(not rusted thru) I'm A buyer,my quarter panel is in bad shape,I realy don't want to buy A whole car ,but not opposed to the idea. Thank-you.
Sorry I don't.do you have the passenger side vinyl top molding for a 1971 Plymouth Satellite?
I'll check but don't think I do right now.You wouldn't have the lower dash bezel extensions off a 68 GTX/satellite/belvedere/road runner? Right and left.
Looking for complete wiring harness 73 charger se 400 big block
Looking for some seat belt covers in blue, medium blue I believe for a 71-72 plymouth?
Sorry sold them already.Looking for front marker light assemblys from the 66 4 door
Do you have the defrost duct and hose for a 66-67 coronet and the driver side sail panel molding for same years?
Sorry I don't right now.Any radio and or heater delete plates for a '64 Polara?
