markbob
Hey all
I have installed the pertronix 2 in my 318 coronet today
Bypassed the ballast resistor and installed their new flamethrower coil
The pertronix system install went very well
I regimes the engine and set the idle speed around 850
When I took the car out for a spin the car started to idle very rough and died.
I restarted it and realized my voltage was dropping with brake light application and the fact the engine slows a bit in gear
I increased the idle a bit and now it runs much better however I must have a loose connection somewhere because when I hit a bump in the road sometimes the car starts to run rough
I checked the alternator....14 volts coming out
I am loosing 1.2 volts between the alternator output and the pos bat terminal
Does anyone else have this problem?
Which connections should I check first?
Thx
MB
Thx
MB
