i have a 68 charger 383 with tko 5speed conversion from silver sport. i am trying to adjust pinion angle. i have read everything on the forum and lots on internet about it. i think i 1/2 understand it. my output shaft is 2.2 deg down and the pinion is about 2 deg down clearly not ideal ending up with a drive angle of close to zero so not good. there is no easy way to get output shaft up so i was thinking i could use 2 or 3 deg shim in rear to rotate up so that they would be close in opposite directions. i was thinking of using 3 degree so that would be 2.5 and 1 giving drive angle of 1.5 and some room for rotation up in acceleration. or maybe i should do 2 deg to get 2.5 drive angle but more room for upward acceleration. i currently have standard 5 leaf in rear but an looking at replacing with espo 6 leaf.
with the tko the output shaft is actually about an inch lower than the pinion, if i measured right and the drive shaft itself is level. opposite of what i am use to i guess. anyway i just finished car with rebuilt engine, new tko, new driveshaft, and new pumpkin. i have only had it up to about 50 mph and didn’t notice any vibration in either acceleration or deceleration but clearly a drive angle close to zero results in premature wear.
any advice/correction appreciated, sorry about having to post another pinion angle thread lol.
