dvw
The idea is to have the engine/trans centerline (C/L) parallel to the rear pinion C/L under acceleration. Pinion angle on any set-up first depends on the engine /trans angle. Then knowing what type of rear suspension you have. How far does the axle housing rotate upward under load? How far does the housing separate from the body during the run? Knowing these parameters you can set pinion angle correctly. Using the eng/trans angle you set the housing X number of degrees lower than this measurement. The X number depends on you suspension. In this case Calvert states 2 degrees. if the Eng/trans is down 2 degrees in the rear. You would set the housing to 0. If the eng/trans is 0 you would set the housing 2 degrees nose down. If the eng/trans were 4 degrees down in the rear you would set the housing 2 degrees up. Now you can see why knowing eng/trans C/L is necessary. The angle of the drive shaft is only a function of the distance between the the height/length of the engine trans C/L vs the height of the pinion C/L. In cars its not a concern. It can be a problem in a raised 4wd truck where there is a large distance. Pay no attention to driveshaft angle in this discussion. It means nothing. As far as springs. A S/S spring has a very stiff front half. The Caltrack bar is now the stiffing member between the housing and the frame. The spring now is only used to hold the car up. A lighter compressed spring has more stored energy than a stiff non compressed spring. That is why Caltracks will work better with the lightest spring. Unless we are talking big HP, like past 2000. Then the engine torque will apply the tire to hard. But that's another discussion.
Doug
Doug
