383man
Yes I finally have the cake to build the eng I really wanted to build for my 63 when I put it together. I plan to build a pump gas aluminum head stroker. It will be around 500 cubes and have about 11.0 comp. I will use a cam for max power that keeps the cyl pressure below 190 so it will run good on pump gas. I also plan to use CNC Eddy RPM heads. All I want is to still drive the car all the time including to the track and run in the 10's. That will make me real happy to drive to the track and pop off 10 second et's. I am looking for 10.80's or better. I also plan to change the converter to maybe an 8" unit. I will let you all know when I start building it. This will replace the .030 over 906 headed 10.0 comp 440 in it now. Ron
