HT413
Semi Pro Bowler
Ok I checked the yellow wire for voltage today, it has voltage and it fluctuates up and down.
What do you mean 'fluctuates'.
OK after calling the guys over at M@H Electric, i found out that my headlamp harness is from a 73 b body, mine is a 74. According to M@H, i need to buy a 74 harness for my car if i want it to start. He also brought up the seat belt relay, not sure what to do about that; i am not sure what year car my seat came from. So after x mass, i am going to replace the headlamp harness; if anyone has any ideas on how to jump or set up the seat belt relay please me no.
If you were around those days, like I was, you'll recall the govt mandated a seat-belt interlock system that prevented starting the car unless the belt was fastened... it was a horror show... I know... we used to bypass the crap on customers carsNot sure I buy the harness thing. Seatbelt relay, ok, maybe.
I don't want to really put a damper on your situation as these types of problems can be nothing but an *** pain. I am not familiar with Classic Industries offerings for replacement harnesses. That is because there is only one type of OEM reproductions that I would recommend to use...M&H harness sold exclusively through Year One. Price? You bet they are expensive!!! However, the cost in blood pressure and stress is far more greater with the other offerings out there than with the M&H. Basically a plug n play set up and after a few little bugs they work like a champ. With the addition of the MAD Electric Ammeter bypass, and some headlight relays wired in, you shouldn't have any issues. So now you have what you have. What to do? Get yourself a color wiring schematic for your car and along with the FSM...Factory Service Manual...go through each circuit and path and make sure that all is hooked up accordingly and color coded correctly. It sucks I know, but when it comes to the electrical aspects of any type of machine, it must be done right the first time otherwise you will be experiencing exactly what your are. It is just possible that your harnesses were not built correctly and you have the wrong circuits wired incorrectly via the color codes. Good luck and I know most here including myself will gladly help you get through this. It ain't any fun...DAMHIK...cr8crshr/Tuck
