Brian Carino
New Member
Can anyone tell me if you can put a polly head water pump on a 360 LA engine? I know it will bolt up to it but does it work correctly?
I will add this .
what I have is a 64 polara I put a 360 in and put a polly head water pump on it so the alt. and power steering pump would bolt up to it. but now I am having a problem with the motor running hot. tried thermostats, timing , water wetter. motor is not running lean. engine is recent rebuild, radiator has been flushed.engine is a 1975 with little compression. I am running out of ideas.
Brian
I will add this .
Brian
