Joel Talka
Hi,
More questions... I'm looking to convert this car (my 66 Coronet 440) to power brakes. Previously discs were installed up front keeping drums in the rear. I have the booster/Master Cylinder installed and am looking to plumb the unit. I did buy some pre-formed lines but they need to be extended in order to mate to the proportioning valve. The unit I am working with is from Classic Performance Products and for a disc/ drum or disc/disc set up.
Couple of questions..
1 - The proportioning valve has two small connection ports to the rear (fire wall side) and one larger port to the front (radiator side)... Which is front and which is rear?? Th CPP documentation is not clear..
2 - Plumbing the front, should there be a single line to a "T" splitting fluid left and right or should both front lines connect to the proportioning valve?
When I got the car each front brake was plumbed directly to the proportioning valve. I have no idea if that was correct or not..all I know is that it took lots of pedal pressure to stop the car.
Thanks again,
Joel
Thanks again,
Joel
