steve340
Depending on how bad the rear brake locking is I would normally go down 1/8 to 3/16.
I even went down 1/4 on a light car.
Essentially you are making the back brakes weaker to the point they cannot over-power the traction of the tyres. Rear locking under braking in wet weather is going to try and turn the car around and is something to avoid completely.
The .906 is 1/32 drop and would be OK if your car is close to right. Your call if you want to try them.
It will be better but if you have been testing in the dry you would get a different result in the wet.
This is just a best guess. If you have been testing in the dry - go down at least 1/8.
