Thank you you're so right that is my issue right now I have a 66 satellite with a big cam 440 in it and he put a ssbc disc brake kit in it and use the original power booster and I have a tough time breaking I'd like to know if I could use that 15/16 master cylinder on the existing power booster provided I had enough vacuum
I, too bought a disc brake manual to power conversion kit (by MBM), but I hear some say if you have a big cam, you won't have the vacuum to operate it. I think my cam specs are listed below...I don't know if this is considered a "big" cam or not (???)
CLAY SMITH ENGINEERING CAMSHAFT: Model MB*H-300-8-BHL
Valve timing (based on B rockers)
“IN” opens 42, closes 78.
Duration at .50 = 244 degrees
In valve lift = .485. In valve adjust, .000
“EX” opens 78, closes 42
EX valve lift .485, EX valve adjust .000
This is all greek/ mumbo jumbo to me. The car is 440 (4 speed), has headers, and I am planning to install a
Mopar: P5153525 intake manifold (this is to replace a M1 hi rise on it now, Mopar intake P4532174 single plane).
Do I have too much cam for a power brake booster?
