Hemi ,
Look at the fuel tee on the center carb! The throttle return arm is in the middle of the FITTING!
Today 2 calls to PRO MAX + email with pictures = STILL NO RETURN PHONE CALL OR AN ANSWERED EMAIL! I left a message to send fittings from carb to fuel tees and I'll rest it on the manifold similar to the stock lines. Yes some SET UPs came with a fuel rail, Still BAD BUSINESS
On PRO MAX's part,
So you cut the arm to accommodate space so it will return?
if you can find any of the old magazine article pictures when those carbs first came out i'm pretty sure a fuel log was used. what was sent you is what my friend has. his is a maintenance headache. pretty sure he's had to replace the float bowls at least once from eating up the soft threads at the fuel inlet.
Ok I'll go back to my mock set up tommorow ,but is the vent arm necessary ???
LEW your in box is full!!if you can find any of the old magazine article pictures when those carbs first came out i'm pretty sure a fuel log was used. what was sent you is what my friend has. his is a maintenance headache. pretty sure he's had to replace the float bowls at least once from eating up the soft threads at the fuel inlet.
i always adjusted the rod to keep the vent closed. i didn't like the fuel residue on the bowl.Hi LEW ,
Can the vent on the center carb be BYPASSED or plugged, or would it need a new metering block?
Thanks,
Mitch
With that being said, I can eliminate the rod and keep the vent closed? Also I'm in the process of getting a Magna Fuel log from Summit, Your correct on that statement ,AS USUAL!!i always adjusted the rod to keep the vent closed. i didn't like the fuel residue on the bowl.
I've got stuff cleared out, thanks.I have an original air cleaner, as far as inbox bring up conversation ,then there is an option box, go to leave conversation, press twice and your in business , it's a PIA .
