I sent my 6bbl carbs to Ben at Promax to have them install some of their unique parts (angled rear outboard carb idle screws, center carb merering block, jetable plates, etc), the correct rebuild kits, repair a threaded hole for the accelerator pump, and give them a basic tune.
I also ordered the entire SS braided fuel line kit.
Although I wasn't having any leaks with the factory fuel line setup, it's horrible for anyone who may need to remove it and reinstall as part of jetting and other tuning on an ongoing process. The braided lines and fittings are much easier to deal with.
Mine worked out great, and the other work and parts and labor were top notch.
The biggest problem I had was not flushing the new braided lines before I installed them. They had a significant amount of braid clippings debris inside the lines which went into the tiny orifices of the carbs and made it run really bad until I disassembled everything to flush it all out. I was thinking I should do that but I was rushing to install everything for Cruisin the Coast week, so I didn't.
I too had a really bad time getting Ben on the phone, with the exception of the couple of days I needed help with the cleanup of the debris and other questions once I had got them back.
